DVC's
Nukedsodapop
OK, heres my problem, i have i four channel amp bridged to two channels, the problem is that one channel seems stonger than the other one, or putting out more power because when i had my two twelves in there one moved more han the other, and the gains were the same.... Would this be a problem with a DVC sub wit both channels on them?
EXTREMLY bad for a DVC with both channels on different coils
its not good to do it when they are 'close' to the same output. you should never hook a speaker up like that anyway.
;P
actually if he has the amps that are bridgable via a phone cable, he can set teh gains on the master amp and the second amp will have the same gains. Otherwise, your stuck with using a DMM or VOM to set your gains correctly.
Nukedsodapop
Nukedsodapop
Somewhere
AznRevlAzn
