Durango03's Skar 12" Enclosure Build (Moble Design)
Woot! Thank you Double 07. Cant wait to see the magic you perform on this enclosure! Also thank you @moble enclosurs for the awesome design and @Keep_Hope_Alive for the guidance and idea's.
As all audiophiles know, a proper enclosure is the key piece to any system. With that being said I believe I lucked out and was able to pick a few of the greatest minds on CA in order to accomplish my goals. Thanks fella's.
Cool.......You need to plan a ROAD TRIP up here after I build the BEAST and we will help you install it and tune your amp/ amps.......NO EXTRA $ REQUIRED.....But TIPS are accepted.....lol
****. 4 Separate chambers, Double baffle with a flush mount and a curved outer edge on the port in the middle? Pretty sure I've never seen
a box design quite like this. I'm going to have to ask mobile what's up. Excellent work double 07, can't wait.
****. 4 Separate chambers, Double baffle with a flush mount and a curved outer edge on the port in the middle? Pretty sure I've never seen a box design quite like this. I'm going to have to ask mobile what's up. Excellent work double 07, can't wait.
The upward firing subs & ports were based on ideas and guidance given by Keep_Hope_Alive, as well as the 4 chamber (to ideally achieve perfect coupling of wavelengths given that each sub to port to cabin distance is the exact same traveled as opposed to a rear firing port where the wavelengths from 2 subs would always be longer than the other 2). These few details were given to Mobile and this was the end result. Personally I am very happy as to how the design turned out and I knew Mobile would have the creative touch to achieve my goals.
Btw, Loving it Double.. 1000 thank you's!!
double 07
double 07
Etowah, TN
double 07
