Duramix 4058 sanding?
It's not that bad sanding . Eats up some paper , but it's not too bad . I tend to use a file to get things to the shape I want first . Then just use the paper to smooth it over //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So you have used 4058 before?
i got a response on mp3car.
its hard to sand, i used this stuff before, its like hard plastic, but its da bomb, i have the 30 second stuff to but rairly use it, i find that the "fusor" stuff works well too...
but my most favorate stuff in the world is the stuff i made my dash from...
DLn' 120 pics right now so i will take one in like 5-10 min...
made by pro form, "pf 702" "rigid plastic epoxy repair kit"
no shrinkage, can be baked and painted, no pinholes, excellent sandability and good for smc and frp
The 4048 is the same as the 4040 only slighty thinner.
It sands the same as 4040, which is like hard plastic.
It was used as a filler because it was thinner and easier to manuveur.
hmmm. i think i may just use rage. you have any tips for it to stick well to plastic?..besides roughing it up
dont use body filler, it might pop! abs and other plastics expand/contract with heat and filler doesnt. go with the duramix. You dont need the mixing gun if thats whats turning you off.
i used body filler on my old screen mold, it seemed to work fine, although a crack did occur.
maybe i will get the duramix, i'll spend the extra time sanding.
btw i already have the mixing dispenser //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Megalomaniac
Mr.SQ
Megalomaniac
The Colony, TX
Megalomaniac
Mike Mccabe
