DUAL XDMA6630 won't turn on unless I pull & replace fuse
sek
PA
This is the 2nd unit doing the same thing. When it's turned off, it won't turn back on. I found that if I disconnect the power and reconnect it will then turn on. Is there anyone who knows about this issue? Dual Co. is no help.
Dual is normally a cheaper brand built with substandard parts....so lots of problems....
437
633
983
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
927
sek
sek
PA
huberoy123
