Dual Voice Coil Sub, BRAHMA!!!
You could wire both coils in series and make it a bridged mono load on your amp, or you could run your amp in "mono mode" and just plug each voice coil into each channel. I think that would work.
tell us how it sounds!
I don't know alot about car audio but I know more than most of the people my age around here but I don't understand what the briged mono load is can you explain that. And I will tell yall how it sounds
bridged mono means using both channels of the amplifier as one. The Plus from one side goes to the plus of the speaker and the minus of the other side goes to the minus of the speaker. Look at the amp or the manual to see which channel needs to be the + and which channel needs to be the - of the bridge.
85ss
85ss
Clarksville, TN
EarDrummin.
