Dual SA X v.2 wiring
  • 6
A-a-ron
Need some recommendations on wiring/amp set up for (2) 12 SA X v.2 D2 subs. Two smaller mono amps or one large? Amp recommendation? there seems to be many opinions on amp quality. I'm willing to spend money and not looking for 3k watts for $40 lol.
Well lets see...what's your budget?
There's a lot of sales going on now....wolfram 3000.1 amp for 400 bucks
Cab 1600.1 for 200 bucks
Twisted Sounds 2.8k This amp has been tested to do dam near 4k.
I guess I'll answer that by saying $400 seems insanely cheap compared to the many years ago when I was into car stereos. I would've expected to spend $1k+ for an amp and Ive found many in that price range but if the guts are the same and reliability/performance are equal then to me it's a no brainer to go with the less expensive option. My taste in music is mostly low, heavy bass. Yelawolf, Rittz, etc. I'm not looking to enter comps, I just want to be able to melt some faces when I turn it up //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yeah the twisted sounds is a good deal., also orion xtr 2500 did 3200rms at 1ohm on a dyno it's under $400 https://www.amazon.com/XTR2500-1Dz-CEA-2006-Compliant-Amplifier-XTR2500-1D/dp/B00DDZQSHS ts maybe better more power anyway..
That's POWER... dem X's will get down on an 8K amp!
Over 4000 posts in less than a year?...//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
OBSESSED WITH ME ARE U? at least 500 of mine weren't to insult someone for no reason..
I'm just saying it looks like you are a post ho!.. 4000 posts in less than a year... wow... that's gotta be some kind of a record...//content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif
what i win? see lots of those are from contest and replying to peeps asking y i run at 2 ohms and things like this.. see these 2 are because u replied to me for no reason..
The booby prize!.. I'll let ya' know... lol... don't hold your breath!
LOL...thanks for the responses. Another question...with a rating of 3.8 ohms each if i wired these to show the amp 1 ohm would the amp actually be seeing less than 1 ohm since they are both 3.8?
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
194
881
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
852
A-a-ron
A-a-ron
Wisconsin
shredder2
    May 20, 2024
    May 20, 2024
