Dual Amp and Power Wire Size?
  • 2
bossman_19
Two amps.
1. Rockford Fosgate R500X1D Class D Mono Block----------For my 1 RF P2D2-12 sub
•RMS Power Rating:
◦4 ohms: 300 watts x 1 chan.
◦2 ohms: 500 watts x 1 chan.
Says use 4 gauge.
2. Hifonics ZRX600.4 A/B------------------ Running 4 6x9s
•Max Power Rating:
◦4 ohms: 75 watts x 4 chan.
◦2 ohms: 150 watts x 4 chan.
◦Bridged, 4 ohm: 300 watts x 2 chan.
•8 gauge power wire to use
So how big should the main power wire be? 2 gauge? Then into a DB with 4 gauge going to the subs amp and 8 gauge going to the speakers amp both like what they recommend.
Or could I go 4 to both amps from the DB from the 2 gauge main power wire?
Or can I just run 4 gauge everywhere. With fuses in the main wire, then after DB one in each power wire? Just worried that its too much power going into one wire.
Just need a clear path to take and go from.
I already have a 8 gauge wire kit from past hook-ups.
I plan on doing this my self so don't tell me to get it professionally done...
868
751
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
765
bossman_19
bossman_19
St.Louis
Side Show
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
