SPL Z1X-3000d any good?
Babykinns
Does anyone know if the SPL Z1X-3000d is any good? I'mma be running 2 12" kicker cvr 12's dual 2Ohm off it for now might sell it on ebay to get a zx750.1
I got a guy who is willing to trade me it for a million d2229 7" touchscreen.
The specs for it are
•Class D 3000 W Monoblock Power Amplifier
•RMS Power Output
◦4 ohms: 1100 watts x 1 chan.
◦2 ohms: 1800 watts x 1 chan.
◦1 ohms: 2300 watts x 1 chan.
•High Speed Digital Circuitry
•Fully Regulated PWM Power Supply
•Four Way Protection Circuit
•1 Ohm Stable
•Bridging Synchronization
•Variable Low Pass 50Hz-150Hz
•Variable Subsonic Filter 15Hz-40hz
•Variable Subwoofer EQ @ 45Hz
•Phase Switch 0-180
•Remote Dash Mount Low Level Gain Control With Cable
•System Distress Indicator
•Mono Speaker Output Connectors
•Gold Plated Heavy Duty Power and Speaker Terminals
•Dimensions: 16.8" L x 11.25" W x 2.25" H
It's most likely going to put out under half of rated. Plus you also have to run at 2 ohm because of your sub's cool configuration. Not trying to burst your bubble , but I would sell everything and start from scratch.
Does anyone know if the SPL Z1X-3000d is any good? I'mma be running 2 12" kicker cvr 12's dual 2Ohm off it for now might sell it on ebay to get a zx750.1I got a guy who is willing to trade me it for a million d2229 7" touchscreen.
•RMS Power Output
•1 Ohm Stable
•Phase Switch 0-180
POWER ACOUSTIK FTW!!!! lol
[quote name='4OZGLOVES']It's most likely going to put out under half of rated. Plus you also have to run at 2 ohm because of your sub's cool configuration. Not trying to burst your bubble , but I would sell everything and start from scratch.[/QUOTE]
Actually these are decent boards, this board shares with a few other old skool'ers including the older Power Acoustik A3000db(<Was not made in a Power Acoustik Build house) :fyi:). The power acoustik with this board acutally will run .5ohm daily with decent electrical as well do RATED or very close to the 2300....
@infamous_e46; has or had the power acoustik previously
[quote name='bgowdy31']Actually these are decent boards, this board shares with a few other old skool'ers including the older Power Acoustik A3000db(<Was not made in a Power Acoustik Build house) :fyi:). The power acoustik with this board acutally will run .5ohm daily with decent electrical as well do RATED or very close to the 2300....
@infamous_e46; has or had the power acoustik previously[/QUOTE]
Board means nothing
Well, if it does rated your CVR's are going to be in some pain, sub upgrade plans?
I plan on setting the gain about 2mm below half that should be around 900-1k rms at 2Ohm right? And also I plan to get either some cvx's eventually or 2 jl 12w7's
Babykinns
Babykinns
Nelsonville, OH
Beatin'
