This is Dom's reply after telling me over and over the FIRST alt would fit. I was sure it wouldn't fit because it didn't but yet...he assured me so I went off and tried to install it.
> Dominick Iraggi wrote:
> Ahhhhhhhhhhhhhhh. I told you it wold click.
> Yours is the only Safari that can not use the CS-144 style case. We have a different case that does not use any brackets or anything like that. It bolts right up. All you need to do is connect the plug and run your 1/0g.
> I will attach a copy of a UPS label to return the alt you have now and I will ship the correct model as soon as the other one gets here. Please return all parts that came with the alt
> I apologize for all the hastle you have gone through.
> Thanks, Dom
This message here is about the 2nd alternator I received from Dom.
Roberto Medina wrote:
> Hey Dominick,it's been quite some time since I've had the alternator you sent me but I've yet to install it because I was running an Iceberg alternator but it's not up to par anymore because of a bigger install so I've had your alt sitting pretty in the box that you sent it to me in.Well,I had a couple questions on the alt you sent me..At the moment you may think I'm an idiot but I just don't want to mess anything up and I'm not too knowledgeable about alternators,I know what they do but I just don't know how they do it entirely.I have plenty of pictures I'm attaching to this E-mail so hopefully you'll be able to point out what I can do/what to do.I have also measured the mounting bolt holes and it seems like your alt has about 1/8 to 1/4'' difference from center of the stock alt's bolt holes but it wasn't the most accurate measurement(I need a bigger caliper) so I can't really tell if it will fit.I'm not worried about the fitment though,I just wanted to talk to you before I tried to install it and messed something up,thanks a lot in advance.
This is the last contact through E-MAIL I received from Dom
Did you try and mount it? I believe it will fit from the measurements we took here.
I called Dom and he told me it will fit. The 2ND one DIDN'T so he said he'd make me a bracket. All I needed to do for said bracket was go out of my way, and create a template and he would cut a bracket for me out of who knows what. So...I went and created a mock-up bracket and called Dom back so I could fax or send him the exact size template for him to make me. Well guess what? After like 50 calls a few emails I decided to give up. It was obvious Dom was dodging me because he didn't want to help me any more. So in the end I went out of my way to create my own bracket for the SECOND alternator he sent me that he said WOULD fit. So much for buying a bolt on. Dominick is nothing but a lying sack of sh1t, avoid all business with the guy if possible.
