Dual Alternators????
all good options.
SicAudio...LMFAO
Heres the story behing my POS iraggi alt that i OWN and i tried to use except for in the 6 months of me trying to use it, it failed 6 or 7 times (its failed so many times i dont even remember now). Now i do remember that 3 out of those times the alt DID NOT even work out of the box. 2 times it didnt last more than a couple hours. Dominick actually owes me about 800 dollars right now and is refusing to pay me and keeps coming up with excuses to not pay. There is a court judgement against him...
your point?
you dont think nate or any of the others have ever had an issue? cuz for every 1 person that says a bad thing u know full and well that their are 1000 that have good to say.
so i ask again your point?
its all heresay without proof anyways
so ?
your point?
EPIK PHIAL !!!!
This is Dom's reply after telling me over and over the FIRST alt would fit. I was sure it wouldn't fit because it didn't but yet...he assured me so I went off and tried to install it.
> Dominick Iraggi wrote:
> Ahhhhhhhhhhhhhhh. I told you it wold click.
> Yours is the only Safari that can not use the CS-144 style case. We have a different case that does not use any brackets or anything like that. It bolts right up. All you need to do is connect the plug and run your 1/0g.
> I will attach a copy of a UPS label to return the alt you have now and I will ship the correct model as soon as the other one gets here. Please return all parts that came with the alt
> I apologize for all the hastle you have gone through.
> Thanks, Dom
This message here is about the 2nd alternator I received from Dom.
Roberto Medina wrote:
> Hey Dominick,it's been quite some time since I've had the alternator you sent me but I've yet to install it because I was running an Iceberg alternator but it's not up to par anymore because of a bigger install so I've had your alt sitting pretty in the box that you sent it to me in.Well,I had a couple questions on the alt you sent me..At the moment you may think I'm an idiot but I just don't want to mess anything up and I'm not too knowledgeable about alternators,I know what they do but I just don't know how they do it entirely.I have plenty of pictures I'm attaching to this E-mail so hopefully you'll be able to point out what I can do/what to do.I have also measured the mounting bolt holes and it seems like your alt has about 1/8 to 1/4'' difference from center of the stock alt's bolt holes but it wasn't the most accurate measurement(I need a bigger caliper) so I can't really tell if it will fit.I'm not worried about the fitment though,I just wanted to talk to you before I tried to install it and messed something up,thanks a lot in advance.
This is the last contact through E-MAIL I received from Dom
Did you try and mount it? I believe it will fit from the measurements we took here.
I called Dom and he told me it will fit. The 2ND one DIDN'T so he said he'd make me a bracket. All I needed to do for said bracket was go out of my way, and create a template and he would cut a bracket for me out of who knows what. So...I went and created a mock-up bracket and called Dom back so I could fax or send him the exact size template for him to make me. Well guess what? After like 50 calls a few emails I decided to give up. It was obvious Dom was dodging me because he didn't want to help me any more. So in the end I went out of my way to create my own bracket for the SECOND alternator he sent me that he said WOULD fit. So much for buying a bolt on. Dominick is nothing but a lying sack of sh1t, avoid all business with the guy if possible.
well da mn lol.. i own a mechman alt btw.. it just isnt enough at idle for me so im going dual
im going to order another mechman alt once i find a dual alt kit to work
^ another person
did you know in his subforum on SteveMeadeDesigns.com he made a thread for feedback. However if you look that thread is now gone, i wonder why you must ask? because there was so much negative feedback in such a short amount of time it was going to kill any future customers that was stupid enough not to fully research about iraggi befoe purchasing
really? do you have the "rhino" series if so sheesh lol. what does your setup consist of?
i have the large case 200amp with voltage regulator
well my motor isnt stock, the big cam and ect.. makes it idle low
and the alt i has doesnt hit high output until after bout 14-500ish rpm
and when my bass hits the alt slips so bad..
4)12"inch kicker cvxs
1 zx2500 kicker mono amp
2) 2400 kinetiks
yeah i know your saying with those 2400 i should be fine but the alt just cant keep up dueing to it slipping and what not, so i figure add a second alt + with the serpentine setup il be A-okay..
i have the large case 200amp with voltage regulator&
2) 2400 kinetiks
ahhh, okay i thought you had the 150 at idle alt. hmm belt slip? can you take a picture of the alt's "belt" wrap?
its just a simple v-belt except the alternator has the serpentine groove
4solobaricz
BOSS
4solobaricz
Illinois
4solobaricz
