robob2
I'm picking up 2 Jl 8w3 subs and want to put them in a single sealed enclosure. Is there any problems with putting two drivers in one enclosure?
Yes. Take the recommended volume for that sub and double it. Also you might want to reinforce it by putting a piece of MDF in between the two subs.Does the box volume need to double when using two drivers?
That is completely optional... it will work just as well if they share the airspace.Yes. Take the recommended volume for that sub and double it. Also I beleive you are supposed to seal the drivers off from each other so you'll want to add a piece of MDF in between the two subs.
