9 91'Hatch 10+ year member Member 35 0 Tacoma Dec 9, 2007 #1 how do you wire it from the amp? Click to read more...
rollerdj 10+ year member Low End Master 4,773 0 Bloomington IN Dec 9, 2007 #2 what amp are u runing. we need to know that to figure out what ohm load to put it on
M miker 5,000+ posts CarAudio.com Veteran 5,503 19 Wayzata, MN Dec 9, 2007 #3 the12volt.com is your friend.
rollerdj 10+ year member Low End Master 4,773 0 Bloomington IN Dec 9, 2007 #4 if it's a single sub, u can eather do 8 or 2 ohm. most likely u'll be running 2. but we need to know if your amps is 2 channel or mono.
OP 9 91'Hatch 10+ year member Member 35 0 Tacoma Dec 9, 2007 Thread Starter #5 its a mtx2301 mono block(i thinnk the model is correct i know its a 300 watt amp) i know for sure that its a mono block though
94Mazda626 10+ year member Senior VIP Member 484 0 SK, Canada Dec 9, 2007 #6 Wire VC's in parallel for a 2 ohm load, both +'ve to the + on amp, both -'ve to - on amp.
