Dual 2-ohm voice coils, ...
Buckshot
Could you wire both in series and end up with a 2 ohm load overall? Thats right correct?
My only other option would be for .5 Ohms, correct?
I need to know for my amp selection, I'm not totally sure if those are right, but I'm pretty positive.
So I need a 2 ohm, or .5 ohm amp!? Correct?
if you have 2 subs and both are dual 2 ohm, then you are correct.
not at all you have more choice's then that you can run @ 4 ohms 2 ohms 1 ohm or .5 ohm
what amp you should look for ? what kind of power can your speakers take? how much do you have to spend?
not at all you have more choice's then that you can run @ 4 ohms 2 ohms 1 ohm or .5 ohmwhat amp you should look for ? what kind of power can your speakers take? how much do you have to spend?
How do you run those two subs at 1 ohm?
1000 RMS a piece so ~2kw @ whatever independance.
Rockford RFR-3112
Buckshot
Buckshot
Michigan
Buckshot
