headtrnr 10+ year member Senior VIP Member 192 0 Toronto May 6, 2006 #1 which set of terminals do i use on the mono, the left, the right, or one from each i'm wiring it to get 1 ohm so i know how to do that. just having a brain fart today Click to read more...
OP headtrnr 10+ year member Senior VIP Member 192 0 Toronto May 6, 2006 Thread Starter #4 does it matter if i take the + on the left and the - on the right cause that is the easiest for me
V vetkilr 10+ year member CarAudio.com Veteran 3,429 0 brandon,fl May 6, 2006 #5 nine.1 bridges internally thus wire each coil to its own side and the amp does the rest.
revrider1 5,000+ posts Hmmm... 30,475 5 Down South~3rd Coast~TX May 6, 2006 #6 nine.1 bridges internally thus wire each coil to its own side and the amp does the rest. Click to expand... Yep, that is why I said run one coil to each
OP headtrnr 10+ year member Senior VIP Member 192 0 Toronto May 6, 2006 Thread Starter #8 yeah but can i do it my way just cause that is less wire that i have to use and less wire that i have to make neat
revrider1 5,000+ posts Hmmm... 30,475 5 Down South~3rd Coast~TX May 6, 2006 #9 So basically you want to run from coil to coil inside the box save wire.
OP headtrnr 10+ year member Senior VIP Member 192 0 Toronto May 6, 2006 Thread Starter #10 yes - to - and + to + and the use one wire from inside to the amp so can i use left + and right -
revrider1 5,000+ posts Hmmm... 30,475 5 Down South~3rd Coast~TX May 6, 2006 #11 NO, use the + and - from the same set.
