Dual 12 Enclosure Port Help
Think of it as an L and you are looking down into the port. You want to measure starting at the front edge of the baffle (ie put the tape measure lip over baffle edge and run it towards back of box).Yea the longer port running parallel to your side will end 3.75 from your back wall. your shorter piece will butt to it and be 3.75 away from the back. The side closest to the back should be flush with the end of the longer port and attach inside the longer port. So the short piece will be 6in long (8.625 - 1.875 distance to center of port - .75 thickness of mdf of other port).
Ok so the port wall running from front to back will be 17.5" long and the one running from side to side will be 6" long right? if not what did i do wrong?
How does this look? Bracing look ok? Port walls ended up being 17.5" long on the one from front to back, and 6" long on the one going from side to side, now that is 6" long including the .75" from the first port wall, does that sound right?
@NASTY08IMPALA ;
@DukeNut ;
Thanks for all the help already guys. Hopefully this will be the last amount of help ill need :D
bmk6795
bmk6795
Spartanburg, SC
DukeNut
