Downside to soldering?
headbussaboi
Is there a downside to soldering 2 pieces of 0 awg together then heatshrinking the connection? Do you lose anything? Just wondering because I really don't wanna use my other lengths unless I have to. The piece in question almost makes it to the trunk, I'm just short 3 feet or so:(.
i asked the same question in a differnt forum hahahaha!!!
I dont see why not, but im waiting for an answer myself.
It would be cheaper and probably a better connection since you are soldering the wires together and just reinsulating them
you just really lose a bunch of time, I'd use a coupler instead. solder has a slighty lower current transfer rate than copper. If you do decide to solder, just keep in mind that you want to have as much wire to wire contact as possible
I would think soldering something as big and heavy as 1/0 would be a weak point in the connection and more easily come apart than a coupler with a pressure screw.
I had to use a propane torch to solder my 1/0 when I soldered the ring terminals for my Big 3 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
But I do agree with everyone that said soldering is way better (because the connection is rock solid, physically and electrically)
If you solder correctly and get the wire heated down to its core and the solder reaches the core. Otherwise if only the outer strands get soldered then it would be weak.
headbussaboi
headbussaboi
Saint Paul, MN
GearGuy2001
michigan born
    May 14, 2026
michigan born
    May 14, 2026
