the subs were wire that way cuz was only to test i do not run 4 ohms dayli thas why i unplug the series wires and make it paralel, and i dont admit u or anybuddy call me lier !!!!most likely when you went to setup the head unit you had a friend hit the push terminals yank out the small series jumper cable and parallel the conveniently pre cut and proper length wires to wire them parallel that are there chillin, and now you trying to act all bad 4ss like your sheity crossfire is badhss.
u want to the smar *** guy ok..... it makes 900 AT 4OHMS not 250 like its rated.... its rated 1k at 1 ohm but i dont even think about pushing the gain up at 1 ohm cuz probably is putting out way more than 1 k thats wy i make the questions of running no sub to test... but if it makes 900 at 4 ohms i ask, who much can i makes ate 2 or 1 ohmso what the truth really is, is that your 1k amp only makes 900 watts lmao
Good amps usually double in power as the load resistance drops in half so if 900@4 should be 1800@2 and 3600@1u want to the smar *** guy ok..... it makes 900 AT 4OHMS not 250 like its rated.... its rated 1k at 1 ohm but i dont even think about pushing the gain up at 1 ohm cuz probably is putting out way more than 1 k thats wy i make the questions of running no sub to test... but if it makes 900 at 4 ohms i ask, who much can i makes ate 2 or 1 ohm
This seems very wrong. By all accounts those amps will make 1200-1400W. IF you are seeing 60V on your DMM either you are hard clipping it or the amp will protect or blow up if you try to do that into 1 ohm.
you do not read the post? my amp was open and mess with by croosfire rep, they not stock so i have been told by the previous owner, the guy hit 162.7 with 2 15"s in 2004I dont know, probably like 2000 at 2, and 4000 at 1 ohm. Is that what you want to hear?
Or if you want actual numbers, check the graph you linked. Crossfire didnt sell a 3k amp labeled and priced as a 1k amp dude
like u see on the vid just 0db test tone and a quick test to see what number it gives at full gain, i do not want to test 2 or 1 ohm cuz my 2 ohm subs (2 pioneer) cant handel full gain and same for the 1 ohm subs (this 2 alpine run daily at 1 ohm but just like half gain) problably its not a clean signal but i just want to know what kind of power it is making and i got like 900 rms at 4 ohms thatThis seems very wrong. By all accounts those amps will make 1200-1400W. IF you are seeing 60V on your DMM either you are hard clipping it or the amp will protect or blow up if you try to do that into 1 ohm.
nah it was open and mess with at the pawn shop you bought it from and unfortunately at max gain clipping to **** it only makes 900 watts.you do not read the post? my amp was open and mess with by croosfire rep, they not stock so i have been told by the previous owner, the guy hit 162.7 with 2 15"s in 2004
Probably at 20hz ...subwoofers are made to play lowWOW... 162.7?.. goodness gracious!.. @ what hz.... 32?
