gthbryce
Does using a 2 way crossover double the ohm load? Keep it the same? Or drop it?
Yes you are correct, it stays at 4 ohmsSo If there are two 4 ohm speakers hooked to a passive crossover then the ohm load still remains four, It does not double at all?
they want to up their post count but don't know the correct answer so they try to belittle the OP to make themselves feel worthwhile.depends on the crossover but usually a 4ohm mid with a tweeter will still present a 4ohm load.
Why do other people on here answer with immature responses, just help the guy out.
