Double baffle flush mount, how do you do it with a jig saw
Going to be building a wall this week, my first, also going to have a double front baffle so I can sink the subs in and give some more rigidity. Going to be 4 15's on a 32"high X 32"wide baffle. Subs have a cutout of 14" and an od of just under 16"
What I "think" I have to do. Is simply clamp the 2 baffles together before any holes are cut, find the exact center of all 4 subs and drill the 4 holes through both boards, then just use that as a reference with my "compass/circle drawer" to make 14" cutouts on the first board, 16" on the second
Finding centers kinda boggles my mind at this time of night though, any pointers
Clamp the two together cut at the same time, and then take the top part off, and cut the hole whatever size it needs to be to sit in flush. Put the top board back on and glue it.
what i have done is line up the top two baffles and clamp them real good. next draw a line horizontally down the center of the baffle on top then two horizontal line spaced out accordingly so the subs have sufficient amount between them. once you have done that you should have two points of intersection. drive a nail with a hammer right in thoze intersections or drill a hole that will be small enough for a nail to stick into. once you have done that you can seperate the boards. oh yeah make sure both holes go through both boards. now seperate the two baffles.
now make a circle jig with a scrap piece of mdf. drill a hole somewhere on the sheet all the way through. from that hole measure half of the outer cutout diameter and mark it. now on that mark drill a hole all the way through with a bit that will allow a pencil or pen (whatever your using) to fit snuggly in there. now do that for the inner cutout as well. once your jig is all done take a nail and drive it into the MASTER hole on your jig and then nail it into the hole on your baffle. place the pencil in one of the remaining two jig holes (either sub cutout or outer cutout half diameter.) now just swing that bad boy around. do that accordingly for everything else.
once your circles are drawn use that jig and make the hole larger for your jigsaw blade to fit through. you c where im going with this??? when make'n the larger hole drill all the way through the baffle as well for your starting point. now secure the jigsaw by any means necessary. ANY! do that for all the cutouts mang! and WHAM perfect cutouts! works for me.... well i have a router now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
stop being a cheap *** and get yourself a router and a jasper jig, you'll wonder how you ever cut circles without one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah, clamp/screw the baffles together temporarily and you can drill all the center holes you need. then just use a 14" diameter jig and a 16"... and go slow with the jigsaw lol
If I just had a jigsaw, i'd do it ^^that way. Then I would go the Home Depot and buy a router.
WOT
Banned
WOT
Toronto,CANADA
psych0ticnemes1
