don't understand
audiobahnuser18
Alright guy's kinda lost here was at my work then when i went on break car started up fine no problems then like 12 at night i have a remote start went to go do it wouldn't start and alarm goes off cause everything goes crazy when my car is dead. well went in really hoping would start with key it did but it was really strugling checked my battery voltage it's normal etc....nothing was left on new h.o. alt ran big 3 im not sure maybe something to do cause it was cold and rainy out? please help i don't want to be stranded at my work one night:(.
yeah that's what i was thinkn to like the auto kill safety but i have it so u just hit the brake and it turns off so no switch there . but im not sure i checked battery volts good there , alt putting out what its supposed to , no lights were on , sensors all good but im gonna run a diagnostic's test 2morro at my college i go to see if i can find something since they got all the tool's there etc....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks for the help guy's:)
safty switch would be a cheap looking toggle thats under the dash..
you would flip it off if you plan on working on the motor that way you cant remote start it & chop your hands off.. most would be under the dash panel.. if not its prolly grounded (always On)
Peace troy
oh alright that switch my bad man i know that switch i actually helped put my alarm in so i know where most of my wires are at etc....i actually used to work at a custom shop and that's where i put it in at:).
I had the same problem in my car. Every now and then for no reason my car would just not start, absolutely nothing would happen, the battery was fine, but the starter wasn't even engaging.
Turns out the factory Keyless Entry/Security system (which featured a starter kill) wasn't receiving the exact voltage signal it needed from my aftermarket paging alarm that was put in. Basically the "everything's ok" signal my new alarm was sending to the factory alarm didn't match up, so sometimes the factory alarm would freak out and disable the starter. The only way to fix it in my case is to wait about a half hour.
A quick adjustment to the new alarm and it stopped, or at least hasn't done it again since.
audiobahnuser18
audiobahnuser18
Mi
maldecido33
