Does your system sounds like...
if you want it to sound balanced to you, then the right would end up being a little bit louder after you set it. You could adjust it with your balance setting on the H/U.
the right is louder than the left sometimes? or that they just sound a little bit different? How do I correct this or is this normal..... wich side should be louder for the driver's seat pleasure?
Imaging. You just have to make sure all the speakers are facing you, or if they are off axis make the left side more off axis since it is closer to you than the right side (therefore louder if it is off axis the same amount).
Edit: right is louder then left, ahh, just make the left side more on axis or the right side more off axis.
So I should make the left side louder than the right....? I know on Axis is that its aimed at the driver and off axis is not, but how do I make them more on axis off axis without moving the speaker... I have the stock HU with an audiocontrol EQL btw.
You can't do it w/o moving it, you could just balance the hu a lil more to the left.
Youhearthat?
Youhearthat?
Chicago, Il
Decado
