Does wire make a difference?
Squirrel18
Ok thanks.. I have some actual "car audio wire" thats 1/0 and it seems slightly bigger. I only had a few feet so it wasnt enough to use. I did compare my wire to the old 4 gauge I had and its def bigger. I should be good though..i have a 145 amp alt,big3 upgrade and i'm going to run a 1500-1800w amp. I was just curious if the internals of the wire made a difference (big strands vs little) . I see some wire labeled as "oxygen free) ..so i didnt know if made a difference. Thanks for your help
electricity travels on the surface of the copper wires.
so the more strands of copper wire you have the more surface area there is for the electricity to flow over. - that being said - im pretty shure the wire you have will work ok for your system.
im pretty shure there is some realley complex mathmatical equasion out there that dictates how much surface area is needed to properly conduct x amount of power over the wire before reaching critical yeild - but im not that exited to google it for you.
lol
electricity travels on the surface of the copper wires.so the more strands of copper wire you have the more surface area there is for the electricity to flow over. - that being said - im pretty shure the wire you have will work ok for your system.
lol
So I guess all those copper buss bars people use are useless.
Squirrel18
Squirrel18
Lincoln, Delaware
bland
