Does this subwoofer go with this amp?
absavino
Hi,
Here is what I have:
Amp = Kicker ZX400.1 4ohm mono = 200 x 1, 2ohm mono = 400 x 1
Speaker = Kicker CVR10 2ohm per coil 400 RMS (dual)
When I purchased these, I thought amp 2ohm 400 x 1 = speaker 2ohm @ 400, these should then match. I then read that the both coils must be connected to a source of amplification. When in parallel, 1ohm load is generated and when in series a 4ohm load is produced. None of these speaker setups produce the 2ohm that I was wanting so the amps match the speaker.
What would be the best configuration? If I wired the speakers to 1ohm what effect would the amp have since it only states 4 ohm and 2 ohm mono? I could do the 4ohm speaker setup and then the amp will put out 200 RMS at 4ohm but I worry that the speaker would be under powered.
Any help or recommendations would be appreciated.
Thank you.
The amp will overheat and go into protect and stop working if you run it at 1 ohm. If you push the sub with 4 ohm's 200rms you'll be fine, it will be under powered a little but it's not gonna ruin it or anything.
Thanks for your input. I have decided as another poster recommended to get the 4ohm subwoofer and wire it in series to get the 2ohm.
absavino
absavino
Dallas
Goindef154
Mike Mccabe
