nyg052003
I have the crescendo 800.4 and it has subsonic filters for both sets of channels. I know what I set the other amp to for my sub, but what is it necessary for my Hi's?
Well subsonic filter is essentially a high pass filter for a subwoofer but it can be used for speakers if you wanna cut off the low frequencies from your speakers. Set it to around 100hz and move it down until you feel the bass from your speakers get muddy then move it back up a notch. What kind of speakers are you running?I have the crescendo 800.4 and it has subsonic filters for both sets of channels. I know what I set the other amp to for my sub, but what is it necessary for my Hi's?
polk audio db 6501Well subsonic filter is essentially a high pass filter for a subwoofer but it can be used for speakers if you wanna cut off the low frequencies from your speakers. Set it to around 100hz and move it down until you feel the bass from your speakers get muddy then move it back up a notch. What kind of speakers are you running?
yes that's what I have channels 1-4 set on, HPF and about 120 hz. Dial for subsonic is all the way down. I will confirm with Crescendo tomorrow. Overall system sounds great and I set the amps at a volume of 35 out of 62. Have a Pioneer deh 610 bt and has 4v preouts. Eq is flat and no other enhancements at deck or amps as far as bass boost is used. Sub amp is about halfway. Channels 1 n 2 are halfway and channels 3 n 4 (rear fill), is a little more than a quarter of the way.i wouldnt think you would be using it at all for your highs i would imagine you have the selector switch set to HP and have that adjusted to a certain point, if not then you have your passive crossovers doing whatever there set to for your highs if there components, otherwise it can be used as a bandpass mode maybe??
yeah a few guys enlightened me about it and I understand a little more about it now. I'm hitting up everyone that replies though to check out my thread " Ideas to cover amps " .........//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifSince you are already high-passing those speakers, the sub-sonic filter is not needed. It would not hurt to set subsonic higher, but it won't really help either.
