does the shape of a fibreglass box matter?
shape does matter....but not enough that you should be concerned about it....
if you had a concert hall, things would be different, but the acoustics of most automobiles make box shaping for acoustical reflections pretty much pointless.
Not for the reasons mentioned . But when using fiberglass, shape does matter . A flat fiberglass panel will need 2-3 times the reinforcement a piece of mdf the same size would need. In curved sections though , fiberglass is at it's strongest //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok another newbie question...
if i make a plug of the rear wheel well area of my trunk, with a flat mdf front "baffle", can the port then be extended out from this box, (whatever the required length I need is...
eg... if I build the box from the box plans thread 1.75 @ 32.... the port is 33.625" so can i make a port thats that long from the side of my plug???
not quite understanding what your asking . Are you asking if the port can extend outside the enclosure ? If so , sure . Just remember to account for the extra volume in the enclosure that the port is no longer taking up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
like with the port sticking outside the box?
That's what I was trying to figure out , then he shows two sealed enclosures . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Port outside the box is fine as long as you take into account the fact the port isn't inside the enclosure taking up space //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
punch
punch
Ontario, canada
fbi90909
