Like thisLooks good other than u need a fuse for ur batt to alt and from front bat to back batts
Yes if u have ofc 1/0 and 250 if u have ccaWhat kind of fuse should I use for the alternator? 300 Amp?
He redid the drawing with a fuse on the run from front.to backNO, front to back batts need to be fused at BOTH ends...
with ONE fuse, he needs TWO, one at each end. Both batts give off current, so if one length of wire shorts it will pop the fuse, but the rest of the wire to the other batt is still liveHe redid the drawing with a fuse on the run from front.to back
Im using Rockford Fosgate RFK1 1/0 AWG wire. Im using a XS Power D5100 XS Series up front and 2 Kinetik KHC2000Yes if u have ofc 1/0 and 250 if u have cca
Yea ive never done that if a fuse pops on the main power run between batts the whole wire is dead unless it comes free from the fuse holderwith ONE fuse, he needs TWO, one at each end. Both batts give off current, so if one length of wire shorts it will pop the fuse, but the rest of the wire to the other batt is still live
