Does my equipment have potential to put up decent numbers?
darkhunter139
I know there is no way to predict the exact numbers a setup could hit but I am just wondering if I have potential to hit decent numbers with this stuff:
15 inch FI SSD in a ported box tuned to 33 hz
diamond audio 800.1 D3 (should be able to do about 900 watts)
Kicker 0 gauge wiring, with big three done soon hopefully
All this will be in a 94 Honda accord (seats can fold down if that matters)
Think I could hit decent numbers if I install right? I know these kinds of threads are usually criticized, I know the install has a ton to do with it but equipment also has some //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
15 inch FI SSD in a ported box tuned to 33 ghz
Yea, I would think that would be able to do decent numbers depending on box size, but you should really think about tuning to hz instead of gigahertz //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
****it. I wanted to use the gigahertz line
I'm glad you worded this thread the way you did
And yes, you can get some reasonable numbers out of that setup. Expect 50s? I wouldnt, but respectable numbers, yes
lmao oops on the ghz
I was being so careful at wording this post so I would not get flamed and maybe get some good answers and a typo screwed me over //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
trunk car??
It will be in the trunk of my 94 accord. Seats will fold down (Will this help my numbers?)
Here is the box.
Its almost finished just have to cut the circle and terminal holes out and then carpet it.
If you have the skills, build a box with interchangeable ports. Higher tuning will help increase numbers, but you'll be able to swap out the ports for daily driving.
My box is already done pretty much. I could probably build another one and just swap out boxes though.
I will see how it goes with this one then decide if I want to try that.
darkhunter139
darkhunter139
PA
darkhunter139
