does increasing sealed sub encolsure volume increase spl?
mac336
My 8w1v2 is currently in a small sealed box. I find that it has trouble maintaining SPL at even the upper end of the low frequencies. Would getting a slightly bigger sealed box help with this? (I believe that the current box its in may be even smaller than what its recommended for).
If the design is in less than recommended, then at 90 or 0 phase "tuning" of the sealed box can increase spl below that frequency at 90/0 degree phase response, and an increase in excursion will occur below that point, increasing spl, but decreasing spl above that. It is a tradeoff. Just have to make sure max excursion is not a factor below sealed "tuning" frequency. Other than that, yea, its worth putting it in a bigger box to increase lower end response output.
Ported if youre looking for more SPL. Dont get me wrong sealed subs can get loud but normally Ive found that larger sealed box= hitting lower frequencies. Maybe just try some polyfill to give you an Idea.
Mainly because I love how the sealed sounds. The 8w1v2 is inside the cab and plenty loud enough, my only complaint is the lack of low frequency. I dont even want really low freq, just reasonably low but the spl cuts out when it gets lower than midbass
I was thinking about going with a small ported sub, but I want to keep the tight bass and am afraid the ported will be alittle too loose for my taste
could definitely be worth going for a slightly bigger box, is there any reason you aren't going ported? Could be another option worth looking at
mac336
mac336
New Orleans
Chrispy
