Does box shape matter or just volume ?
girafe06
I recently upgraded to 2 12s. They came in their own box and sounded great but the box wont fit under that basket of electronics that hangs under the rear deck.
So i put them in my old sub box which i built my self which is smaller but fits. Apparently it is too small because in this box they are about half as loud as the box they came in.
So i need to build a new box and here's the question.
Does the shape of the box matter as long as it has the same cu ft?
Because the box they can in has the same height and width but is shorter than the one i built. It is like a cube but stretched to a rectangular prizim.
Now the one i will be building will be just wide enough to fit between the wheel wells,and just short enough to fit under that basket of electronics, plus clearance for the speakers themselves which will be facing up. It will then be longer from front of car to rear of car wise to make for the same volume as the box these new ones came in.
So overall, the distance from the sub magnet to the back of the box will be less than the box the came in which is basically two perfect
cubes glued together.
Will this produce the same sound?
Thanks!
girafe06
girafe06
orlando fl
813thumper
BP1Fanatic
BP1Fanatic
