Does AWG make a big difference?
Alright looks like I'll be upgrading to 0AWG for my power wire..
Another question..
Since I upgrade the power wire to 0awg, should I upgrade the ground on the battery to 0AWG too? If I do, do I replace the ground wire on it right now? or do I run a different ground wire from the side terminal of the battery on the yellow-top, since I'm running the power wire from the side terminal already.
Another question..
Yes, make sure your ground wire is of the same size as your power run. I would run 1/O from the batt to the trunk and use a dist. block with 4 gauge coming out of that to the amps. Just remember when you go DOWN in wire size you have to fuse it. So a fused dist. block would be a good idea.
XaznKewLguyX
bloop
XaznKewLguyX
SoCal
adam71
