Do you use or not Terminal Cups ?
  • I love them
    Votes: 5 31.3%
  • Stupid Cups
    Votes: 11 68.8%
  • Total voters
    16
I use a hole... then i run the necessary amount of wire inside the box... then I wrap electrical tape around the wire to where it is almost to thick and tug it back thru... probably not the best way to seal it up, but it effective and fast.
For a fiberglass box I use those :http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=091-1152
For MDF box I use those :
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=091-1154
I used the terminal that mledez posted and I liked them but little expensive. Using a terminal cup is stupid, your a building a box with 3/4" MDF and you use a 1/16" plastic cup in an area..... In some application I won't be surprised that the cup completly bend and crack.
Just ordered those terminals in the second link //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
im just so lazy i run the wire through the port hole.
I Difinitively will consider the DjWeeDY suggestion and the simple choice of poundindak69... Thanks a lot
I use those as well as I don't have to wait for shipping and they're cheap yet strong enough to not cause any issues with noise.
Oh, and to the thread starter: Don't worry about your English; you are easier to understand than many of the high school graduates in the United States that are on this forum.
Only problem with that (I'm using the same one), is you gotta use small wire, cut a huge hole in your box for it to fit, and the plastic nuts are hard to tighten enough so they won't vibrate loose without stripping them
I use 12 gauge wire with mine and I have no problem getting the wire in nor do I have issues with them vibrating loose. The hole cutout can be stressful but not if you're good with a jigsaw.
There is no better connection than copper to copper. They don't make voice coils out of steel for very good reasons; one being it is not a good conductor. There are no solid copper terminals on todays subwoofers that I am aware nor are there any solid copper connectors other then some butt connectors. The fewer connections you have the better off you are.
As mentioned before drill a hole slightly larger then your speaker wire and run it directly from your speaker terminal, or with our subs twist and tape the lead wire connection, tape or knot the wire so it won't pull out of the box and add a little sealer if you think you need it and you're done.
mledez
mledez
Venezuela
iagrdshaka
