Do in-dash equalizers really work?
Originally posted by denim []in overall sound out put, be it quality or getting every watt out of your amplifers
you can get every watt out of you amp with a 1v signal you don't need a line driver for that as far as SQ it will only help in the way I said before
, it helps geatly in knoise reduction,
read other posts
but then there is other thing s you can do to get rid of noise, usually balanced out puts like 16volts does the trick] ]
correct-------if it was a inducted noise--------there are many types of noise
OK here is another question...
The HU has 3 outputs... Front/Rear/Sub with crossover in the sub output, and other gadgets...
Then the Four.1 as 1input and 2 outputs... what would happen to all the HU gadgets if I'm only using a front output to the 4.1...
Won't I loose all the extras in the HU because I'm only using 1 preout or the 4.1 is way much better than having cheap HU crossovers in the front/rear and sub preouts?
THX
THX
only gadgets you couldn't use is the -------internal x-over if any and the HU fader
Originally posted by chris229 guys ---------- if there aren't any problems to start with you AREN'T going to gain anything
what I think I was trying to say was that he will get much more out of the wattage as in a cleaner stronger signal, when I jumped my voltage up from 4 volts to around 12 or 13 it was a hugge difference, all the speakers were humming at full tilt so much so that I had to crank down the amps a decent amount, but keeping in mind I had 21 feet of RCA's to push the signal through
kmu
kmu
Tucson, Az...
denim
