do i want 2 ohms or 4 ?
It all depends soley on the amp you are getting or have. Neither 2 or 4 is better than one another, it just depends on what you are powering it with.
since this sub is a dual voicecoil, you are going to wanna get the 4 ohm version, which will enable you to wire it down to 2 ohms. basically your ohms help you out with you amp, you have to match them up to the ohmage your amp is stable at. you can wire them higher but you should never go lower. so buy the 4 ohm speaker and wire it in parallel to your amp.
Pro_built7
Pro_built7
Richmond, MI
blackbonnie
