LegendaryLemon
I want to make sure before I place an order that I'm buying everything I need for my install.
I'm going to install 2 13Kv.2 subs off a JBL BP 1200.1 amp and eD 6000s v.2 off a Kicker KX600.4 amp.
I'm looking to buy from KnuKonceptz :
(1) In-Line Waterproof ANL Fuse Holder w/ Fuse (300A)
(1) KonFUSED 2 Way Distribution System (150A,150A)
(2) Gold Plated 4AWG Ring Terminal -Black
(1) Blue Krystal Kable 4 Channel 6M Twisted Pair RCA Cable
(1) Blue Krystal Kable 2 Channel 6M Twisted Pair RCA Cable
(15 ft) Kolossus Kable 1/0 Blue Power Wire
(8 ft) Kollosus Kable 4 Gauge Metallic Blue Power/Ground Cable (4 ft for running from distribution block to each amp)
(6 ft) Kollosus Kable 4 Gauge Silver Pearl Power/Ground Cable (3 ft for grounding each amp)
(15 ft) Klear Kable Blue 16 Gauge Speaker Wire (for 6000s v.2 and subs)
I already have a battery terminal to use.
The 6000s will be going in the back for right now and I won't have any speakers for up front . Since I can't get them to fit in the front I will be waiting a couple weeks before I have the money to buy other speakers. I just want to figure out if this is a complete list of everything I will need to install all this in my 95 Toyota Corolla.
Also I'm thinking that running this off my stock electrical system is going to be a problem so I was considering upgrading the Big 3 at the same time. Should I go with 0 awg wire and if I do how much would I need? I read that 5-10ft should be enough depending on the size of the engine compartment but I'm not very car savy and would prefer if someone could give me an opinion or point me in the right direction.
One other thing, it won't do any damage if I use a fuse thats bigger than I need correct? ie. a 300a fuse between my power wire and battery? Is there a difference in fuse quality or is a fuse simply a fuse? ie. darvex.com has Stinger fuses for like $9 while they also carry Sound Quest fuses for around $3. Am I paying for different quality fuses or is it simply the name?
