DLS Amp Question
frkkevin
On the DLS amps there is a cap input.. is it safe to lets say hook up a kinetik battery to the cap input and the normal batt to the regular input ... I mean I see no diff doing that vs hooking up a cap there..
anyone know?
from the manual
Power terminal for A3, A4 & A6
These models have double DC inputs. The terminals
are internally connected so it´s enough to
connect just one of them. If you want to reduce the
voltage drop to the amplifier, use both inputs. The
extra DC input can also be used for the connection
of a Power Capacitor or an extra battery. See the
example above. These amplifiers requires a
powerful fuse holder like the FH2B with an ANL 150
Amp fuse (when using 2AWG / 33 mm2 power
cable).
Ground Terminal ( GND )
POWER IN
BATT+ REMOTE GND
FM1 107,3
Fuses
frkkevin
frkkevin
US
denali804
