Sold ******DLS A7 Big Five Channe Cheap!*****
Worlddre
Big Darkie
I have up for sale here a DLS A7 5 channel amplifier. This is an awesome amplifier ive used it for a year without a hiccup and it has served me well. It has full 3way active crossovers built-in with a bandpassable rear set of channels so if you do not have an active processor or capable Hu this amplifier will do all the work. Amplifier comes in original box with bass knob and manual. Asking $550 + shipping. And btw it is in perfect mechanical and cosmetic condition as it was well cared for. And i have plenty of refs just search the name in the feedback forum.
Number of channels 5
Amplifier class AB
Output power in 4 ohm 4 x 60 W
Output power in 2 ohm 4 x 100 W
Mono bridge mode 4 ohm 2 x 200 W
Mono sub channel 4 ohm 300 W
Mono sub channel 2 ohm 440 W
Mono sub channel output in 1 ohm 600 W
Frequency range 10 Hz - 50 kHz
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,3 - 7 V
Input impedance > 10 kohm
Filters channel A & B HP: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filters channel C & D HP: 80 - 400 Hz. LP: 0,3 - 4 kHz / 3 - 40 kHz (x10)
External cooling fan terminal 1
Remote base level control 1
Remote phase shift control 1
Power consumption (idle) 1,1A
Power consumption (max) 120 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 35 A + 2 x 20 A
Dimension (W x D x H) 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inches)
Weight 8,1 kg ( 17,86 lb)
Worlddre
Big Darkie
Worlddre
Charlotte, NC
6spdcoupe
