Distrobution block question
LongThrow
My Kickers be swaggin'
I am upgrading my system. So i bought 4g knuconcept kit with 2 distro blocks for ground and power' 4g to 2 8g outputs. I dont have enough 8g wire, could i use 4g on one of the 8g outputs to my amp?
Kicker 500x1 to power 2 12 inch comps at 2 ohm final. This one would obviously have the 4g
Infinity reference 6 by 8s powered by rockford fosgate prime 75x2 4 ohms will be using 8g for this.
Get a 4ga to 8ga adapter, don't just trim the wire down. That's ghetto.
I just need to know if i can use 4g on the 8g side of my distrobution block, and if itll provide eniugh power to my mids/highs amp and to my 500w sub amp. Door amp will be 75 watts per channel.
Battery - 4g wire - distro block - 4g to sub amp / 8g to door speaker amp. Would that work?
You should be fine, yes
LongThrow
LongThrow
Springfield, MO
jrdnhsnbrg
Mike Mccabe
