distro block
bamaboy
War Eagle!!!
im getting an Pa 3000db, i heard i need to fuse it and get a distro block, what size fuse to get , what kind of distro, and where do i get a good size wire? and what all do i need for this amp? my viper is running off a 4 ga kit from walmart so i know i need a bigger wire, but what else for the PA? and dont have money for alt at the moment
what size fuse for the power acoustik, i couldnt find anything on it on the site, and is knu knoceptz the best place to buy from, where is some other good places for distro blocks for 1/0 wire, and on wielding supply it has other size wire do i have to go 1/0 gauge, or can i go smaller, i have 4 ga right now, so i need bigger wire, distro block with fuse and waht else? and also do i need a fuse up by the batter? i have one with my 4 ga but it is only a 80 amp fuse, where can i get a fuse block for cheap that has a good size fuse for 1/0 gauge? i searched but i **** at using it and couldnt find some of this for what i need because i know the pa dosent have internal fuses
will this work instead of a distro block? http://www.cardomain.com/item/LITRA14 , i can just plug 1/0 wire into it and go(how does it work, just stick it in there and screw it down?, and i will get a 300a fuse for the 1/0 wire at the battery, do i need any more fuses because im low on money now but will be getting paid soon, but will this get the job done at the moment?
1/0 wire from welding supply-17ft sound like enough? for blazer 28$ with shipping
1/0-4 ga adapter 6.95+ shipping
fuse block w/ 300amp fuse(wheres the cheapest place to buy?)
really? i thouht u picked one that was close to how many amps yor amp drew?
fuses protects the wire and battery not equipment. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You want a fuse that will allow your amp to perform to full potential while protecting your car from short curcuit, I would recommend a 100 to150 amp breaker or maxi fuse, I used a 100 amp breaker for a Concept cc1200D and a Concept cc1004 and the breaker only tripped once in over a year.
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
jsloan10
