Distribution Question
  • 5
All_Logix
Formerly CivicGTi
695
Texas
This is probably a really dub question but I can't get a direct answer, Say you want to run a high amp system so you need to run 0/1 gauge, but your car is to small to hide that. What would be the problems that might arise from running 0/1 under the hood and through the firewall, then trying a distribution block right past that to say 3 8 gauge wires. would you need to fuse each one of those individual as well, would that cause any problems
Yeah I thought about that but I really don't want to drill into the trunk, I am trying to do as little permanent change as possible...I didnt even really drill into the firewall I found a plastic grommet and went trough that...any other thought
Hmmm, well if that wire chart is right, then could you run 4 guage for about 10 feet and then distribute it and be ok?
Unless you're going to be burping, in all reality, you'll be fine running 4ga wire the whole way. Music rarely ever gets close to max RMS output. Just use the proper fuse for a 4ga wire and you'll good to go.
All_Logix
Formerly CivicGTi
All_Logix
Texas
All_Logix
    May 16, 2024
    May 16, 2024
