distribution block ????
redrider
maybe a stupid question but here in the future i will be doing an install and was wondering if it was possible to run 1 in 2 out distribution block 4 awg all around? the only reason i ask is i have 4 awg ran from a previous install and this install im running 2 amps so really dont want to rerun the power wire but i have a feeling i will need too lol. thanks for your help or input.
i'd run another wire ,that way you have one for each amp ,or rerun the wire in 0 gauge and use the distro block then .most maxxsonics amps are a bit power hungry ,so there may be to much voltage draw with the 2 amps ,but you really wont know until you get it all installed
figured... i have the 0 awg just didnt want to run it if i didnt have too lol
Add the fuse rating on the amps together and get a wire that will support at least that much current, then you can use a distro to run 4ga to each amp. 1/0 CCA would probably be sufficient
redrider
redrider
jacksonville, fl
redrider
