Distribution Block Q's : Ground/Power
Ruffy
Death to the salad eaters
Would you use one ground point using 1/0 Ga wire going to a distribution block(non fused) then from there split off to 4ga to my amps and whatever I need.
Or would you use seperate ground connections for each amp.
My current plan is laid out in this crappy diagram
Note that brands arent really set. I Did buy the Fuse holder above. But I also have a ANL Fuse holder that came with my streetwires wiring kit. I just took random pics of amps and distro blocks.
Ruffy
Ruffy
Las Vegas, NV
helotaxi
