distortion.....
Solid-state distortion sounds like ***...you should turn off your bass boost, it's not helpful.
"Distortion" is a very broad term though; you mean what does a clipped signal sound like? There are ten million kinds of distortion, some much worse to listen to than others...
my bass sounds good to me.... just someone told me today that there was some distortion in it.... does ne one have a kenwood kdc-2022 headunit or ever had one? i cant find the bassboost on it or anything..... or would that be the loudness button?
"Loudness" would usually be it...there's probably a bass boost on your amp as well.
If it sounds good to you, well, that's really all that matters.
there is a bass boost on my amp and its turned all the way up... my gain is 1/4 the way up and i have it on the lpf and im pretty sure the lpf nob is between loke 90 and 100.... could it be the subs?
Blowing up equipment is how you learn not to ever do that again //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
turn your bass boost off on the amp and go to the gain setting tuorial on this site and it should be low passed between 100-80
Thank you for exactly paraphrasing the same thing that I said in my post above you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BassManB
giggity giggity goo
BassManB
estill co. KY
JimJ
