distorted speakers
  • 2
w9jcm
reno
Hi all just picked up this saleen mustang and started having problems with the stereo. I have a kenwood head with six speakers in front which 4 are run by a kenwood kac-848. And then a sub box with 3 10 inch subs run by a mtx amp. The bass end seems good. I was tinkering with the Inputs on the amp last night and it sounded crisper when i turned them up some so I left it. So tonight i was cranking some bass and suddenly the fronts started to get real cummy like distorted almost like they were blown.. Maybe I did blow them? But it got to dark to keep messing around so tomrrow i will go out and turn back the inputs. And see what happens. Any ideas?
John in Reno
Unless your front speakers are 5.25 inch or 6.5 inch than loud bass will cause distortion and probably ruin them. A high pass crossover should be used to remove bass from small speakers.
Went out this morning and setup the input on the kenwood amp to where it was and whallaaaaaaaaa clean as can be. As for bass on the front speakers.. The MTX is running all the bass the kenwood is running the mids and highs thank you.
I would not opt for the inexpensive Focal's (and I've used/use currently - their products extensively in both car and HT applications) and while a...
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
216
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
113
38
w9jcm
w9jcm
reno
w9jcm
    May 18, 2024
    May 18, 2024
