- Thread Starter
- #16
Civic's don't have power antenna's, correct?
Been a while since I worked on one.
If you have no power antenna, the blue wire usually will lead to nothing on the factory harness side, and, if you're using the power antenna wire for a remote turn-on (which is ok), and you're getting a ground through the remote turn on, something is grounding out, somewhere.
so are u saying i should investigate the remote turn on wire? could there be a slight cut in the remote wire grounding it out?
