dimming lights with h/o alt big 3 and kinetik battery
07vue
8
phx
Hey guys im trying to find out why my headlights and dash lights are dimming with a h/o 220amp alt for excessive amperage kinetic 1800 battery up front and Memphis 1/0 for big three. for the equipment I have a jl hd750.1 and an arc ks300.4 really frustrated I spent a lot of money on getting my electrical and car beefed up to eventually go with a bigger setup and this current setup is causing my lights to dim please help with ways to test. I have clamped it and with a/c on headlights and system up it reads that im only pulling around 70-80 amps from the alternator????
Lighting.is.very senitive ..u will see dimming as small as .2v drop...get hids and it will stop
its excessive amperage but the alt should be drawing more then 70-80 amps and dash lights are dimming as well even at high rpms
starting voltage is 14.9 and drops to 14.4 to 14.2 it fluctuates a little lowest though is 14.2 for big three power from alt to battery ground to engine block another ground to chasis,and from battery to fuse block
07vue
07vue
phx
jrdnhsnbrg
