Diming troubles
alexleon86
Benz
I have two 13.5 W7 and two mono 1000 watt amps pushing the woffers. I also have two MB Quart components and a 450 4 channle Mb quart amp. i have 2 yellow top optima batteries and two capacitors with a isolator connecting evreything together. I need help and suggestion on how to resolved this diming problem and i got this system in a 2003 benz.
sell the capacitors and use the cash to upgrade your wiring under the hood.
do that !!! big three WILL do what you want it to ... without it its hard to have no dimming... if you still have dimming after that it may be because your alt wont charge your batteries fast enough or effinciantly....
The correct answer here depends on getting more info from you. Is there any way you can diagram the wiring for your system, including the location of the isolator. Just do it in Paint or whatever so we have an idea what we are dealing with. Another piece of info we need is the model of Benz you have or at least the alternator specs. Also need to know the voltage you are seeing before and during the lights dimming.
alexleon86
Benz
alexleon86
salinas Ca
loopkiller
michigan born
    May 14, 2026
michigan born
    May 14, 2026
