Digital Designs x1 4 way active processor
79bronco
Signal Processor X1 / X1.1 | DD Audio
4 way (3 way + sub) active crossover... highly selectable
7 volt line driver
1/2 Din size
24db/octave filters
Burr Brown op-amps
This is what you will need to run a 3 way front stage and sub. You can have the controls right at your fingertips. This thing is great. Only selling because it wont fit in my new car. Fit nicely in my old jetta and was a great piece. Bandpass crossovers on each set of channels across a very wide frequency range.
It has some scuffs on the side from being mounted, but it is nothing serious and does not hider performance.
I will get a video uploaded of the unit in action some time this weekend.
180 shipped
USPS Flat rate
Yea that may be the route I go, I'm just tryin to see if that would be compatible with using the stock HU and line drivers. Or if it will still not be suitable enough to get the volume and clarity.
I have all hertz components and am lookin to get more output. The clarity is there but I don't get the volume like it should. I was wondering if one of these would help to clean up and add more input to the amp so that I can get the volume out of the components. It's really expensive to Change out my factory HU, that's why I'm trying to somehow get around changing it out. Thanks for the reply though. I'll keep diggin and see if I can find any more knowledge or help from a first hander.
165 shipped... going active has never been this cheap!
will trade for:
hertz tweeters
sundown 12" subs
soundstream/zapco symbilink equipment
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
79bronco
79bronco
United States
79bronco
    Jun 1, 2024
    May 31, 2024
