Different Port Lengths- Same Box
matt_martin87
OG
This question should be presented only to those who consider themselves "experts" on box design/building.
What would the effect be of adding length to one of my external PVC aeroports? I'd like to tune even lower than what I have now but due to space restrictions, I can only add length to one of the two ports.
Say, to get to a 24hz tune I need an extra 10 inches added to both ports. Could I add 20 inches to one of the ports instead?
I'd like to try it as long as there aren't any major issues involved with a design like this.
If I close off one of the 4 in ports, I wont have enough port area for my 2.5 cube box.
The purpose of the thread is to find out what a box with 2 different port lengths would do to the response curve.
sometimes whats done is done bro. either plug the ports or keep them the way they are, or build a new box. and why do you want to tune to 24hz? all you listen to is chopped and screwed crap?
If I want a lower tuned box I will redesign and build again. That isn't the main focus of my thread.
Since the box has multiple tuning frequencies, id like to know it changes the response curve.
All I can tell you is to try it...
.. But I would plug 1 of the ports....
And make the other port bigger in diameter & length.
( Should be fairly simply as: Cuttin' the hole, Buyin' a 6" - 8" PVC tub, calculating the length, and applying to the enclosure )
.... * Being bigger in Diameter - reduces the length *
But of course the response wave is goin' to change - you have 2 different frequencies in the same enclosure
... It's like you're tryna make a wannabe " ABC " box ( except without a transfer chamber )
I personally think your subs are gonna be outta wack with the different cut off! - If you have a SubSonic Filter - That'll be pivital in this situation.
matt_martin87
OG
matt_martin87
Beatrice, NE
NissanKicker
