Differences in SPL
THe way it was explained to me is the nothing but a difference in efficiency reproducing a range of frequencies. a/b amps do better at high freq, d is better at low, regardless of wattage.
This could be wrong, it's second-hand information from an electronics engineer but we were both a little buzzed when we had this conversation.
THe way it was explained to me is the nothing but a difference in efficiency reproducing a range of frequencies. a/b amps do better at high freq, d is better at low, regardless of wattage. This could be wrong, it's second-hand information from an electronics engineer but we were both a little buzzed when we had this conversation.
I don't think thats right, many SQ subwoofer amps are class A/B
I would say most of the difference is in the amount of distortion. There could be some coloring issues but I doubt it. A lot of home theater receivers use class D full range amps. One per a channel.
fosgate uses class bd b for the sound output d the the power supply but with a 800 watt class ab you wont have enough time to tell if the output is the same because it will have over heated and gone into protect
I think they can do that because of the power supply? I don't know but I would like to know.
So basically there are differences in efficiency both amps whether A/B or D are still going to give 800 clean watts of power to subwoofers? There will be differences in efficiency but still 800 clean watts?
Its all in the design TBH. Any amp design can sound great or terrible.
the 315wrms amp here can take massive swings in voltage from its supply and be fine afterward.
That would depend on the manufacture and how they rate their amps (.01%, .1%, 1% or 10% THD and supply voltage)
But generally two amps of different designs (as in a/b vs D) rated in the same way will be very similar.
The amp I was talking about above is rated for 315wrms@4ohms with 10%THD and 125wrms@8ohm with
cleansoundzz
cleansoundzz
Buena Park
Diplexers
