Difference in resistance.
bloodhound50
MA
When you have a 1 ohm load versus a 2 or 4 ohm load will it cause your amplifier to strain it self more than if it were pushing the same wattage at a 2 or 4 ohm load? Also will a 4 ohm load sound clearer and more natural than a 1 ohm load?
Generally yes it is harder on the amplifier as higher current output is required with lower impedance loads...and current is what creates heat...and heat is bad.
Here is an example; The PG Xenon 100.4 outputs relatively the same power into 4ohm, 2ohm aswell as 1ohm....but you can see how efficiency decreases substantially as the load decreases.
http://carsound.com/articles/publish/article_413.shtml
That said; If the amplifier is rated to handle the lower impedance it shouldn't put a significant enough strain on the amplifier that it causes it to fail. It was designed to handle those lower impedances.
No.
Impedance has nothing to do with sound quality.
Thanks, I heard from Polk when i called to see if my subs where dvc that the sound would be something with quality i forgot what he actually said tho it could have been efficiency.
No.
Nice explanation. Always appreciated.
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are...
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
bloodhound50
bloodhound50
MA
WhoSayWho?
    May 31, 2024
    May 24, 2024
